1994 Ford Explorer
KMEADE
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 187,000 MILES
The heater just stopped blowing out hot air only cold. The temp gauge went up, it was low on water so we added water and anti freeze. I will start the truck and let it run for awhile the temp gauge goes to the middle but still not heat. I thought maybe it could be thermostat. Can you help me
Wednesday, December 10th, 2008 AT 10:52 AM
DAVE H
  • 13,384 POSTS
Yes it could be the thermostat. Check or replace thermostat first. Let me know how it goes?
BASIC HEATER SYSTEM TROUBLE SHOOTING CHART
CONDITIONPOSSIBLE CAUSE
Insufficient, Erratic, or No Heat
. Low Coolant Level
. Incorrect thermostat.
. Restricted coolant flow through core.
. Heater hoses plugged.
Wednesday, December 10th, 2008 AT 11:29 AM
