1994 Ford Explorer
SHANNA
Transmission problem
1994 Ford Explorer 4 cyl Four Wheel Drive Automatic
Trany was gone, put a used tranny in, now it wont start. Does this mean the censors on the tranny are gone?
If so which one is gone -
There is one plug with 5 conectors, and one plug with 3 conectors.
There is also a new starter in the truck.
Oct 24, 2008 at 6:49 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like the park neutral switch may be out of adjustment. try starting it in neutral or move the shifter around and see if you can get it to crank by doing that but make sure you are in it and your foot is on the brakes.
Oct 24, 2008 at 11:32 PM
