1994 Ford Explorer
JEFFDUTY
Computer problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
I have no spark,and the fuel pump doesn't operate when I turn the key. The engine does crank,the battery,the ICM,the coil pack,and the crankshaft position sensor are new,however the engine still will not start. I do get oil pressure when cranking the engine,and if I'm right,that eliminates the timing belt as being the problem. Any ideas on what the problem could be?
Dec 14, 2009 at 10:45 AM
  • 110,251 POSTS
If you are not getting spark or fuel, it could be a couple things. First, is the security light flashing or staying on when you crank the engine? Have you checked the EEC relay?
Dec 23, 2009 at 1:31 AM
