1994 Ford Explorer
BILLYJONES
Electrical problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
94 explorer crankshaft position sensor-does it mount internally or externally to the timing cover do you need any special tools and is there any way you can show me a diaghram thank you billy
Jun 8, 2009 at 4:48 AM
JGAROFALO
  • 489 POSTS
[quote:22262d566f="billyjones"]Electrical problem
94 explorer crankshaft position sensor-does it mount internally or externally to the timing cover do you need any special tools and is there any way you can show me a diaghram thank you billy[/quote:22262d566f]
The sensor is external, but it is behind the harmonic balancer. Most of the time, once unbolted, you can wiggle it out and wiggle a new one in.
Jun 10, 2009 at 7:52 AM
