1994 Ford Explorer
MISSSTRICKER
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
We put a brand new fuel pump in. The fuse is fine and so is the fuel filter. What else could be causing the fuel pump not to be working?
May 3, 2009 at 2:56 AM
FJCLW4
  • 5 POSTS
check the main power and groung to the sending unit. If either are loose the pump won't work
May 6, 2009 at 3:05 AM
