1993 Ford Explorer Water leaking
WEIRDHERROLD
  • 1993 FORD EXPLORER
Engine Cooling problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
It appears water from the cooling system is leaking thru the exhaust system. Is the the block cracked and is this something which I may repair myself?
Saturday, January 10th, 2009 AT 5:14 PM
BMRFIXIT
  • 19,053 POSTS
Suspect head
check headgasket
Sunday, January 11th, 2009 AT 12:18 AM
JOHNH2009
  • 6 POSTS
Pull the middle plug on the drivers side. If it's covered in white crap, guess cracked head gasket or cracked head.
If it's leaking slowly, may be able to cure with a coolent sealent.
Monday, February 2nd, 2009 AT 12:36 PM
BMRFIXIT
  • 19,053 POSTS
Personally not a big supporter of sealer
but it may work for you !
Good luck
Monday, February 2nd, 2009 AT 4:15 PM
