1993 Ford Explorer vacumn modulator valve
154,687 MILES • 6 CYL • 4WD • AUTOMATIC
WNDWLKER2ND
my ford explore with auto transmission shows the
fluid level full the engine oil level was normal
but then one day the engine started smoking
i checked the transmission level it was empty
the engine oil level was then two or three quarts
above the normal range level what is the problem
i am thinking transmission vacumn modulator
valve, what do you think
Sep 29, 2008 at 12:12 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:65b56cd5e5="wndwlker2nd"]Transmission problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic 154687 miles
valve, what do you think[/quote:65b56cd5e5]
It could be, what color was the smoke....
Also check your radiator for tranny fluid....
Does the oil appear milky?
In all my years of Mechanicing I have never come across a bad TVM that dumped that much fluid into the oil pan.
Sep 29, 2008 at 12:42 PM
MTCAIME
  • 13 POSTS
YOUR RIGHT I HAD THE SAME PROBLEM, EASY CHECK REMOVE THE VACUM LINE THAT LEADS TO THE MODULATER AT THE T ON THE RIGHT REAR OF INTAKE MANIFOLD AND SEE IF TRANSS FLUID IS PRESENT.
Mar 16, 2011 at 2:04 AM
