1993 Ford Explorer starter
32,000 MILES • 6 CYL • 4WD • AUTOMATIC
RIPDAKING1020
my starter grinds when i start my truck
May 18, 2008 at 1:12 AM
LEGITIMATE007
  • 5,121 POSTS
its probably staying engaged, you could cause further problems if you don't address this ,like broken flywheel teeth. your starte is getting stuck. its usually a problem with the starter not your vehicle. you'll need to change it or rebuild it
May 18, 2008 at 1:36 AM
BLACKOP555
  • 10,386 POSTS
after it starts it grinds or it grinds when attempting to start the truck?
