1993 Ford Explorer stalls when put into gear
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMESWHITTINGTON
1993 ford exployer
the motor and tranny run perfect but when i put it into gear it stalls hard.i had the same problem two weeks ago and i spreyed out the air flow sensers with electrical parts cleaner and the throtel body with fuel injecter cleaner and it ran and drove perfectly and now i have the same problem..what can the problem be
Jul 25, 2010 at 10:31 AM
  • 110,251 POSTS
When was the fuel filter replaced last? Have you checked fuel pump pressure? Has the check engine light come on?
Jul 25, 2010 at 5:51 PM
