Replace door hinge
115,000 MILES • V8 • 4WD • AUTOMATIC
HARLANM
How difficult is it to replace the drivers side front door hinge
Mar 17, 2010 at 1:06 PM
This is not a difficult task at all. Basically, you want to support the door with a floor jack and block of wood just so it doesn't drop when you loosen the hinge.
Here is a guide that will help with using a floor jack in case you need this info:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Lastly, I am attaching the process from the manual and a picture of the hinge which will show which bolts to remove.
Please run through this info and let us know what questions you have.
Thanks
Feb 19, 2022 at 10:59 AM
