1993 Ford Explorer NEED ADVICE A.S.A.P
KINGREME
  • 1993 FORD EXPLORER
  • 4 CYL
  • 17,500 MILES
I WOULD LIKE TO KNOW IF I SHOULD GO AHEAD AND BUY SOME TRANSMISSION FIX BEFORE I DECIDE TO REPLACE THE TRANSMISSION WHICH IS EXPENSIVE AND THE TRUCK IS NOT WORTH THAT KIND OF MONEY. MY TRUCK WON'T SHIF INTO GEAR UNTIL I GO OVER 55 MILES THEN IT JUMPS INTO GEAR, FOR NOW I'AM SHIFTING THE GEARS MANUALLY. WHAT CAN I DO TO SAVE MY ONLY TRANSPORTATION?
Friday, January 9th, 2009 AT 4:10 AM
KINGREME
Friday, January 9th, 2009 AT 4:11 AM
JGAROFALO
  • 489 POSTS
This could be the vacuum modulator. Check the vacuum line going from the rear of the upper intake manifold to the right side of the transmission. If you have good vacuum there, then the modulator or valve could be sticking or leaking.
Sunday, January 11th, 2009 AT 5:11 AM
