1993 Ford Explorer lights
1993 FORD EXPLORER
14,000 MILES • 6 CYL • 4WD • MANUAL
DAVIDYOST007
when I turn on the lights at night the right side light goes dim, the blinker stays on dim but won't blink. I replaced all lamps but still have the problem. replaced alternator. starter and solenoid for other reasons......help*.* please
May 15, 2008 at 2:31 PM
MIKE H R
  • 3,094 POSTS
check the wiring and light sockets. a;so check the ground. with the light comming on dim means there is a cross over wire or a bad ground. Check the bulb sockets and wires. check for corresions in connections
May 16, 2008 at 4:38 AM
