1993 Ford Explorer leaking fluid
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGEN
i have fluid pouring out between engine and tranmission would this be a seal gone bad or tranmission pump. also the interior light stays on all the time before it worked but it would blow the fuse i had it disconnected for awhile put the fuse in the other day and seen the lightstays on now
Apr 23, 2010 at 6:47 AM
  • 110,251 POSTS
THere is a front pump gasket, and a seal where the torque converter goes into the transmission. Chances are it is the seal where the converter attaches.
Also, it sounds like a problem with the switch causing the light to stay on.
Apr 23, 2010 at 9:59 AM
