1993 Ford Explorer hard starting
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
CNJALCO1
My truck lately is very hard to start. It cranks over fine acts like its going to start but doesn't. after messing with it for a little while ie: pumping the petal and repeated tries starting, it will start , seems like when I change the plugs it fixes the problem for a little bit.Tried changing brand of gas same thing,is there a sensor or something else to look for. help please.............
Feb 12, 2008 at 9:43 PM
  • 75,988 POSTS
Check engine light On or has flashed before?
Last major tune-up?
Test the engine coolant temperature sensor and check the fuel pressure with a fuel pressure gauge calibrated for your fuel system then comeback
Feb 12, 2008 at 9:53 PM
