i replaced the fule pump and the relay and i still cant get the pump to come on
Nov 12, 2009 at 8:09 AM
✓Experienced Mechanic
Are you getting power to the relay? Also, have you checked to see if the engine is getting spark, because if both are missing, you may have a bad electronic engine control (ECC).
