1993 Ford Explorer fuel pump relay switch
MRBIGA69
Electrical problem
1993 Ford Explorer 6 cyl Two Wheel Drive Automatic
Where is the fuel pump relay switch? I can't find it. All I can find is a box on the passenger side with a bunch of wires.
Sep 1, 2009 at 12:18 AM
2CARPRO JACK
  • 11,533 POSTS
There isant a"relay switch", only arelay and an inertia switch.The inertia switch is located on the right side of the trans hump under the carpet up by the firewall.The relay is on the right inner fender under thehood in the power center, it should be a green relay.
Sep 1, 2009 at 12:52 AM
