1993 Ford Explorer Fuel pump relay
MRBIGA69
Electrical problem
1993 Ford Explorer 6 cyl Two Wheel Drive Automatic
My SUV will try to turn over and sounds like it's going to start and then there is a clicking sound. The relay is on the drivers side but I still can't find it. I was told it should be green. Is there a diagram you can show me or explain in more detail?
Sep 1, 2009 at 1:58 AM
RACEFAN966
  • 5,029 POSTS
OK so have you checked to see if it has fuel or spark? What relay are you looking for that should be green. What does it operate. When you say it try's to start what do you mean? Does the engine turn over and it won't start or does it just click and then engine doesn't turn over at all?
Sep 1, 2009 at 3:59 AM
