1993 Ford Explorer fuel gauge
DRUNK247
  • 1993 FORD EXPLORER
Interior problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
fuel gauge does not work how do I fix it
Sunday, March 21st, 2010 AT 10:53 AM
  • 109,896 POSTS
Chances are the float in the fuel tank is bad or there is a wiring problem. You would need to remove the fuel tank and check for power out from the rheostat. If there is no power, replace it (part of the fuel pump) If there is power, check, wiring, the body control module and the gauge itself.
Monday, March 22nd, 2010 AT 7:30 AM
