1992 Ford Explorer
AZUR RICHARD
  • 1992 FORD EXPLORER
1992 Ford Explorer
I just bought a 92 ford explorer and the hand on the gas gage does not work. How would I see about getting that fixed?
Saturday, May 17th, 2008 AT 3:32 PM
BLACKOP555
  • 10,371 POSTS
Take off the wiring connector, and find the pin for the sending unit and hook up a jump wire to it and put it on a + voltage and make sure that the guage can display a full tank, then put on a negative ground of the vehicle and mkae sure it can display a empty tank, if that is good the fuel tank send unit is bad.
Saturday, May 17th, 2008 AT 3:45 PM
LEGITIMATE007
  • 5,121 POSTS
I believe thats a problem with the float sending unit on the fuel pump
Saturday, May 17th, 2008 AT 3:46 PM
