Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine Cooling
Cooling Fan
Clutch
Replace/Remove
1993 Ford Explorer fan clutch
1993 FORD EXPLORER
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEEKS
MEMBER
1 POST
how do u remove the fan clutch so i can replace coolant fan that is cracked?
Feb 2, 2008 at 4:14 AM
MAZDA1003
MEMBER
You need a special set of wrenches to do it. They have them at Napa for about $50-60. Otherwise, you will strip something.
Feb 4, 2008 at 3:20 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
