1993 Ford Explorer COMPRESSION LEAKS AND CAN'T FIND THE SOU
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAVERICKPHOTOS
HAVING A COMPRESSION LEAK WITH LEAK OBVIOUS FROM THE SOUND COMING FROM UNDER THE HOOD. CAN'T FIND THE FAULTY HOSE OR THE SOURCE. SHUTTING OFF IF NOT ON THE EXCELLERATOR, LOSS OF GAS MILEAGE. HOW MANY DIFFERENT COMPRESSION HOSES AND WHERE ARE THEY? ANY OTHER THINGS TO CHECK TO RESOLVE THE PROBLEM.
Mar 3, 2008 at 7:06 AM
BLACKOP555
  • 10,386 POSTS
your best bet is to try and use a piece of gas line in your ear as a scope and when you find the leak you will hear the hissing noise clearly. if this doesnt work take it in and have a smoke test done on it, very simple test.
Mar 3, 2008 at 10:52 AM
