1993 Ford Explorer check engine
LOST707
Engine Performance problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
I was told that I need to replace the hose that goes from the throttle body to the mass air but I am unsure of where that hose is. Can you tell me?
Nov 15, 2008 at 1:41 AM
DAVE H
  • 13,383 POSTS
we need the exact engine size to locate the correct diagram for you ??
Nov 15, 2008 at 2:47 AM
LOST707
iT IS A 4.0
Nov 17, 2008 at 4:53 AM
DAVE H
  • 13,383 POSTS
the "hose" you are looking for is actually a long thin rubber/plastic tube (vacuum hose) that goes from #24 on diagram on the right side of air cleaner assembly .. to the throttle body(carburettor) located at #'s 6,7,8, on diagram ..
https://images.2carpros.com/forum/automotive_pictures/266999_thrott_1.jpg
Nov 17, 2008 at 9:59 PM
