1993 Ford Explorer brake pedal
125,000 MILES • V8 • 4WD • AUTOMATIC
RICKD
my brake pedal keep going to the floor board. we change the master cylinder and there are no leaks. after we bleed the brakes it is good for a couple of days. the brakes work, I just have to press the pedal all the way down to the floor board with no pressure. my mechanic can't fiqure it out
Feb 24, 2008 at 9:39 AM
  • 75,988 POSTS
Does it have an ABS-if so bleed the system see below
https://images.2carpros.com/forum/automotive_pictures/12900_bleeding_1.jpg
Feb 24, 2008 at 6:32 PM
