1993 Ford Explorer backfires
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
SKATER88
i had just got done putting in a rebuilt engine in that has about 30,000 miles on it and got new gaskets on everything, new spark plug and wires, and new hoses, and i went to start it up and its idling really rough and it keeps backfiring all i hear is this popping sound, i thought maybe if i took for a little test drive it would go away but then the car just ended up stalling what could be the problem?
Aug 17, 2010 at 9:09 PM
JIM SHIRRON
  • 77 POSTS
Check your spark plug wires. It might be as simple as two wires crossed
Aug 17, 2010 at 10:15 PM
SKATER88
there in the right spots, is there anything else that would cause it?
Aug 17, 2010 at 10:17 PM
JIM SHIRRON
  • 77 POSTS
Be sure your wires are in the right order on the cap and the plugs. Check your timing using a timing light.
Aug 17, 2010 at 10:24 PM
SKATER88
how do you use a timing light?
Aug 17, 2010 at 10:25 PM
JIM SHIRRON
  • 77 POSTS
You don't have a timing light? Try loosening and twisting the dist. VERY slightly one direction, then the other. Scratch a mark on the dist. and the intake manifold before you do so you can put it back exactly where it was if this doesen't help. If you notice a difference twisting the dist either direction, clamp it down tight and test drive.
Aug 17, 2010 at 10:49 PM
SKATER88
whats a dist?
Aug 18, 2010 at 6:23 AM
