1993 Ford Explorer A/C Heater fan
TUCKER01
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 156,000 MILES
My air flow is minimal and make a noise. I need to replace the fan but cannot find the right part number to replace the fan. Also, what is the easiest way to replace this fan?
Tuesday, March 18th, 2008 AT 9:24 AM
MIKE H R
  • 3,094 POSTS
The heater fan can be changed from under the hood, on the passengers side you will see it disconnect the wiring going to it then remove the three screws that hold it in place. You will be able to gently remove the motor and the fan as one unit.
To cut cost of a new one you should be able to find one at a local jump yard. Match one that cane off the same year and model or they will be able to tell you what ones fit.
Tuesday, March 18th, 2008 AT 10:15 AM
