1993 Ford Explorer 4WD Noise
1993 FORD EXPLORER
157,000 MILES • 6 CYL • 4WD • AUTOMATIC
CWEDELL
4WD will not ingauge or disingauge. When turning corners a sound of grinding gears from the front end. Possible cause, what to do to fix.
Chad
Feb 9, 2009 at 5:07 PM
BILLYMAC
  • CERTIFIED EXPERT
  • 2,204 POSTS
hi chad most likely is lockouts not working.4x4 actuator stuck. good luck billymac
Feb 9, 2009 at 5:12 PM
