1993 Ford Explorer
KGWALLACE88
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 142,000 MILES
When I shift my transmission into drive it acts like it is in neutral it works fine in reverse. My husband changed the fluids and filters but it is still the same. Do you have any idea what it could be?
Friday, March 28th, 2008 AT 7:52 PM
MASTERTECHTIM
  • 4,750 POSTS
Most likely the transmission is bad. Are you hearing any noise coming from the transfer case?
Friday, March 28th, 2008 AT 7:57 PM
KGWALLACE88
This happened about 2 weeks ago but 2 times since then I have been out and started it and revved it up twice and it pulled on off and I drove it around for a few minutes then back home but once I cut it off it did it all over again.
Friday, March 28th, 2008 AT 8:12 PM
