1993 Ford Explorer
MIKLAT
  • 1993 FORD EXPLORER
Transmission problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic 100k + miles
What is the top speed in four wheel high?
Do I need to add any kind of oil to the transfer case?
Can I put it in four wheel drive manually? The 4x4 selector not working
Wednesday, February 10th, 2010 AT 12:00 PM
  • 109,885 POSTS
I wouldn't recommend driving more than 35 to 40MPH with the 4wd. As far as oil, the transfer case is responsible for 4wd. There is a bolt about 3/4 of the way up the back side of the transfer case. Open that. THe fluid should be to the bottom of the hole. I believe your vehicle uses ATF in the transfer case, but confirm that when you purchase it. Also, make sure that is full, but it should be serviced. Refer to the owner's manual for regular service intervals. As far as shifting the transfer case manually, you can't do it.
Thursday, February 11th, 2010 AT 11:16 AM
  • 109,885 POSTS
Thanks for the positive feed back, and thanks for using 2carpros. Com. Let me know if you have other questions.
Thursday, February 11th, 2010 AT 3:52 PM
