Electrical problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
My Windshild Wipers, Windows, And Radio Work Without The Key Being On. What Would Make That Happen?
Friday, August 21st, 2009 AT 11:12 PM
MECHANIC
That is when they should work. If you are refering to them not working in the accessory setting, the ignition switch may be going bad or the rod going to it may be out od adjustment.
