Electrical problem
1993 Ford Explorer 6 cyl Four Wheel Drive Manual
how to unplug speedometer?
Wednesday, April 29th, 2009 AT 4:42 PM
FJCLW4
MEMBER
If you look at the driverside of the transmission near the back you should see a plug that goes into the cone at the end. That is your speedometer. You have to unscrew it out more than likely. Hope that helps.
