1992 Ford Explorer speedometer
250,000 MILES • 6 CYL • 4WD • MANUAL
SUSIEDEN
Our 92 Explorer started just registering about 25mph lower than actual speed. Then would shoot all over the place. Replaced the 17 tooth drive gear, it was very worn, now it is back to registering about 25mph low again. Do we need to replace the driven gear inside the transfer case? Is there an easier way to get to that than to take it apart? Before we replace the 17 tooth, the cable worked when tried with a drill, so were hoping that would fix it but it didn't. Help!
Mar 17, 2010 at 3:31 AM
2CARPRO JACK
  • 11,533 POSTS
Lift and support the rear of the vehicle.Remove the speedometer drive and look in the trans with a flashlight while turning the rear driveshaft, see if the gear is ok,without any grind marks on it from the other gear slipping.Is the gear located in the tailshaft of the trans? If so you should be able to unbolt just the tailshaft an repalce the gear if necessary
Mar 19, 2010 at 12:58 AM
