HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Not Running
SPONSORED LINKS
1992 Ford Explorer will not stay started
TAMPIKO
MEMBER
1992 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
87,000 MILES
When I start my truck it will start but when I get ready to put it in gear to reverse it shuts off
Friday, March 27th, 2009 AT 11:27 AM
MECHANIC
Check the ISC valve, throttle position and mass airflow sensors
SPONSORED LINKS
Friday, March 27th, 2009 AT 12:08 PM
TAMPIKO
MEMBER
1 POST
Where would that be located
Friday, March 27th, 2009 AT 12:20 PM
MECHANIC
Do you have a repair manual? If not you need one this one can be tough to find and fix it requires a certain procedures to follow
Friday, March 27th, 2009 AT 12:28 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Wont Start And Run?
I Have A Explorer That Won't Start. I Was Driving About 25 Miles And Hr And It Just Stooped Running. I Tried To Restart It But It Won...
Asked by
matt67665
1992
FORD EXPLORER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Ford Explorer Cranking But Not Starting
So Today I Did The Fuel Pump On My Car Figuring That That Was The Problem When I Didn't Hear The Fuel Pump Kick On Or Click Or Anything. But...
Asked by
feeblyhurtingu
1 ANSWER
1992
FORD EXPLORER
1992 Ford Explorer Throttle
When I Start My Explorer It Wont Stop Redlining.
Asked by
tmredsox
1992
FORD EXPLORER
Engine Will Not Start Up?
I Turn Off The Car. Then When Back To Restart It. It Will Turn Over But Would Not Start. I Put Antifreeze In The Reserve Then It Started. It...
Asked by
ashmoh28
1994
FORD EXPLORER
Engine Turns Over But Wont Start?
1997 Ford Explorer Xlt Turns Over Won't Start. Sounds Like Someone Cut Off The Belts! Not The Case, Is It A Fuse Or Timing Belt? Or...
Asked by
Kfm111569
1 IMAGE
1997
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
