1992 Ford Explorer VEHICLE SMOKING
TASHANO
1992 Ford Explorer
when i got the vehicle it was smoking. i changed the idle air control valve and the air flow unit. It is still smoking. Can you tell me why?
May 15, 2010 at 11:57 AM
  • 75,988 POSTS
What kind of smoke is it?
May 15, 2010 at 12:39 PM
TASHANO
Very black smoke.
May 16, 2010 at 12:45 AM
  • 75,988 POSTS
Probable causes of an engine running rich are as follows:
1.Fuel pressure not within specs.Can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
May 16, 2010 at 8:39 AM
TASHANO
Thanks for your advice. The engine light stays on. How do I turn it off?
May 22, 2010 at 9:29 AM
  • 75,988 POSTS
Try disconnecting the battery for a few minutes and see what happens-If the check engine light still On-you have problem with a sensor, its wiring or the computer
May 22, 2010 at 11:11 AM
