HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Not Running
SPONSORED LINKS
1992 Ford Explorer Throttle
TMREDSOX
MEMBER
1992 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
195,550 MILES
When I start my explorer it wont stop redlining.
Sunday, October 26th, 2008 AT 5:28 PM
BOBO234
MEMBER
Have you checked to make sure the throttle linkage isn`t stuck in the wide open postion?
SPONSORED LINKS
Sunday, October 26th, 2008 AT 6:06 PM
BLACKOP555
MECHANIC
Vehicle just reving high or the tachometer bad?
Does pedal feel normal?
Could be the throttle position sensor going bad, disconnect it and see? Any better?
Sunday, October 26th, 2008 AT 6:13 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Wont Start And Run?
I Have A Explorer That Won't Start. I Was Driving About 25 Miles And Hr And It Just Stooped Running. I Tried To Restart It But It Won...
Asked by
matt67665
1992
FORD EXPLORER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Ford Explorer Cranking But Not Starting
So Today I Did The Fuel Pump On My Car Figuring That That Was The Problem When I Didn't Hear The Fuel Pump Kick On Or Click Or Anything. But...
Asked by
feeblyhurtingu
1 ANSWER
1992
FORD EXPLORER
1992 Ford Explorer Will Not Stay Started
When I Start My Truck It Will Start But When I Get Ready To Put It In Gear To Reverse It Shuts Off
Asked by
tampiko
1992
FORD EXPLORER
Engine Will Not Start Up?
I Turn Off The Car. Then When Back To Restart It. It Will Turn Over But Would Not Start. I Put Antifreeze In The Reserve Then It Started. It...
Asked by
ashmoh28
1994
FORD EXPLORER
Engine Turns Over But Wont Start?
1997 Ford Explorer Xlt Turns Over Won't Start. Sounds Like Someone Cut Off The Belts! Not The Case, Is It A Fuse Or Timing Belt? Or...
Asked by
Kfm111569
1 IMAGE
1997
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
