when starting it just makes a clicking noise have put a new senolied on it
Oct 25, 2010 at 3:44 AM
✓Experienced Mechanic
No crank at all/nothing/nada when key is engage to starting position
Could be the starter,starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
