Engine Mechanical problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
The starter runes when you turn the key but it does not engage the flyweel. I replaced the starter but it still does the same thing. I have removed the starter and tested it. It works the way it should. I look up in the hole that you mount the starter in and the flyweel teeth look fine.
Just before it started to not work anymore it would make a clunk when it was turning over after it engaged.
Does anybody have any idea as to what I can check t0o fix this problem.
Feb 27, 2009 at 9:21 AM
