1992 Ford Explorer removed and installed
RONALD RUSSO
Transmission problem
1992 Ford Explorer 6 cyl Four Wheel Drive 120000 miles
i pulled the tranny out and changed the shaft seal and reinstalled the tranny but now it will not go into any gear what did i do wrong
Mar 21, 2009 at 3:16 PM
JGAROFALO
  • 489 POSTS
Which shaft seal are you referring to? The driveshaft seal? The converter seal? or the shift linkage seal?
I might suggest that you may not have connected the transfer case shifter linkage (unless you have a pushbutton for 4X4).
Mar 23, 2009 at 12:16 PM
