1992 Ford Explorer removed and installed
RONALD RUSSO
  • 1992 FORD EXPLORER
Transmission problem
1992 Ford Explorer 6 cyl Four Wheel Drive 120000 miles
i pulled the tranny out and changed the shaft seal and reinstalled the tranny but now it will not go into any gear what did I do wrong
Saturday, March 21st, 2009 AT 10:16 PM
JGAROFALO
  • 489 POSTS
Which shaft seal are you referring to? The driveshaft seal? The converter seal? Or the shift linkage seal?
I might suggest that you may not have connected the transfer case shifter linkage (unless you have a pushbutton for 4X4).
Monday, March 23rd, 2009 AT 7:16 PM
