1992 Ford Explorer problems with starting
ERIC J4LQQKS
Engine Mechanical problem
1992 Ford Explorer Four Wheel Drive Automatic
1992 ford explorer will not start, it turns over, and doesnt have a spark. I've changed the crank position sensor, and the computer. It still wont start?
Oct 12, 2010 at 4:09 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Oct 12, 2010 at 4:29 PM
