Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Ignition
Coil
Replace/Remove
1992 Ford Explorer problem
1992 FORD EXPLORER
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHN502
MEMBER
1 POST
My 92 explorer when i try to start it, it will not get fire i change the coil pack and i just put a transmisson in it i no that is not the problem
Oct 14, 2009 at 3:46 AM
Experienced Mechanic
Could be the ignition control module and crankshaft position sensor
Oct 14, 2009 at 5:50 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
