1992 Ford Explorer not sure
95,000 MILES • 6 CYL • 4WD • MANUAL
MSSUNSHINE1977
truck starts right up..i start to go and 1st and second gear is fine. when i shift into 3rd gear theres a hesitation and truck doesnt want to go. after a couple of minutes it goes into 3rd. and there is hardly any power when going up a hill. if im on the highway once i get into 5th it runs just fine. seemd like it loses power when in lower gears. any suggestions on whats wrong. should i change trans filter? you think this will help at all
Dec 12, 2008 at 3:43 AM
  • 75,988 POSTS
It doesn't have a filter its a manual transmission-sounds like you need a new clutch assembly
Dec 12, 2008 at 4:01 AM
