1992 Ford Explorer I WAS REAR ENDED AND GAS SHOUT OUT
LUIS SOTO
Engine Mechanical problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
WHAT CAN I DO.
DO THEY HAVE A SWICH IN THE GAS LINE
Jan 2, 2010 at 3:44 AM
DOCFIXIT
  • 18,828 POSTS
Pump not running? if tank not leaking then inertia switch has cut off pump as it shpuld in accident. Right side transmission hump under carget find switch push red button will reset pump.
Jan 2, 2010 at 4:01 AM
