1992 Ford Explorer heater cord
SEADS1977
  • 8 POSTS
1992 Ford Explorer 4 cyl Two Wheel Drive Automatic
im pretty sure my heater cord is gone i smell a fishy smell like radiator coming from the heat also its leaking fluid or water underneath the car on the right side kind of near the tire is this my heater core or control valve
Dec 5, 2008 at 8:54 AM
BMRFIXIT
  • 19,053 POSTS
I more thing to look for,
dose it fog the windshield when you put the heater on defrost and if so
100 % heater core is bad and leaking
big job
let me know
Dec 5, 2008 at 9:59 AM
SEADS1977
  • 8 POSTS
i did see fog on my windsheild today but how do you know if its the heater control vave and in the meantime what should i do between now and monday when driving i cant get it fixed until then will my car overheat the radiator is new i just had it put on this feb.
Dec 5, 2008 at 11:27 AM
BMRFIXIT
  • 19,053 POSTS
If it fogged on the inside u need the heater core
no valve inside the dash (HVAC BOX)
truck will run hot and will over heat if low on coolant
keep radiator full with coolant
if you do not need the heat
u can bypass the heater core
by disconnecting the heater hoses on the out side and loop them together
good luck
heater core is located inside the HVAC box
Dec 5, 2008 at 11:59 AM
SEADS1977
  • 8 POSTS
is the hvac box the glove box
Dec 6, 2008 at 5:24 AM
SEADS1977
  • 8 POSTS
okay im back i got someone to put my heater core on they did it in 1 hour. now the water is still leaking from up under the car i looked in the hood i can see its coming from a top hose on the right side water is leaking out the top hose whats happening now?
Dec 6, 2008 at 6:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Heater core replacement in 1 hour? I would be afraid of what that might look like....
To replace the heater core you have to disassemble your dashboard, which that alone takes quiet a while to do even for the experienced mechanic, seeing as how it has so many electrical components and other components attached to it..
You better recheck that replacement work, it sounds like one of the hoses was not hooked up correctly or the hose is faulty/loose.
Dec 6, 2008 at 6:51 AM
BMRFIXIT
  • 19,053 POSTS
One hour to do a heater core !!!!!I DO NOT THINK SO
something is wrong for sure
its over 7 hours to do the heater core
get a local shop to take a look at it for you
as who ever helped you I don’t believe they did a heater core job
good luck
Dec 6, 2008 at 6:56 AM
SEADS1977
  • 8 POSTS
it was a hose he didnt clamp back on but it did only take one hour but one more thing my heat doesnt get hotter than the old heater core.
Dec 7, 2008 at 7:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
No offense to anyone but I am just not seeing a heater core replacement in one hour. It's just not possible. I really suggest you having the replacement job rechecked..
Dec 7, 2008 at 7:41 AM
SEADS1977
  • 8 POSTS
do you know why its not hotter than the old one
Dec 7, 2008 at 7:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Did you top coolant back off after leak?
Dec 7, 2008 at 7:53 AM
DAVE H
  • 13,383 POSTS
not hi-jacking this .. but i think he may have just flushed the core for you .. ???? not replaced it
Dec 7, 2008 at 11:35 AM
SEADS1977
  • 8 POSTS
yesterday i was driving i thought i had smelled something burning today i went to crank up the car and smoke was coming out the vents and also through the holes on top of the hood now what is happening?
Dec 11, 2008 at 7:25 AM
BMRFIXIT
  • 19,053 POSTS
HEATER CORE
NO GOOD
Dec 11, 2008 at 10:15 AM
SEADS1977
  • 8 POSTS
i bought it brand new at autozone how can it be no good ok the guy that did it wont be back in town until next week so what should i do in the mean time
Dec 11, 2008 at 10:44 AM
