1992 Ford Explorer fule
FAEMERBOY
Engine Performance problem
1992 Ford Explorer 6 cyl Four Wheel Drive Manual
will start and idal but takes a min
when you try to drive it bogs out and sounds like theris a miss in the timeing
Apr 30, 2010 at 2:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be a bad fuel pump , could be something as simple as the fuel filter needing replaced too. also might check into the fuel pressure regulator. most often it is a fuel delivery issue that causes this symptom.
Apr 30, 2010 at 2:11 PM
