1992 Ford Explorer fuel pump
166,000 MILES • 6 CYL • 4WD • MANUAL
GAYLEH
replaced fuel pump 4 times 4th one not working must be electrical now what
Jan 31, 2009 at 10:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What was the reason for replacing other ones? Is the pump not coming on at all or is it not pumping enough pressure through system? Have you checked fuel pump relays ?
Jan 31, 2009 at 11:05 AM
GAYLEH
they were not switching on and were taken out and tested and were burnt out they were checked because the ford died as if out of gas
Feb 1, 2009 at 5:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What brand pump you using? Airtex and Carter are very poor quality and burn up quickly. Use the Ford recommended Motorcraft or Bosch pump. Also inspect wiring harness and test wires for shorts. How about that relay? Did you test it? It is located in engine bay fuse/relay block.
Thanks for using 2CarPros.com!
Feb 1, 2009 at 6:02 AM
