1992 Ford Explorer fuel problems
DANIELH
Engine Performance problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
I have a 92 ford explorer 4x4 that the eec relay went out on. I have recntly replaced the relay as well as the fue filter and the fuel pump. NowI am unable to get the pressure back up for the fuel system to travel to the engine. i have no fuel going to the engine and no pressure on the line. What couldbe the problem that I will need to check to try to get the system to work to be able to turn the vehicle on.
Sep 29, 2010 at 9:02 AM
  • 110,246 POSTS
Can you hear the pump running? Are you sure there is power to the EEC relay? Are you getting spark to the engine?
Oct 1, 2010 at 6:36 AM
