1992 Ford Explorer fuel in vaccum lines
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARTYEVER
all tha vaccum lines have fuel in them
Nov 27, 2008 at 5:48 AM
ENGINEMAN 73
  • 28 POSTS
DOES TRUCK RUN ROUGH AND/OR DIE? I WOULD CHECK FUEL PRESSURE REGULATOR ON FUEL RAIL.IF REGULATOR DIAPHRAM IS BAD IT WILL LEAK FUEL INTO VACUUM LINE THAT IS ATTACHED.
Nov 29, 2008 at 2:35 PM
MARTYEVER
[quote:886ad821ec="engineman 73"]DOES TRUCK RUN ROUGH AND/OR DIE? I WOULD CHECK FUEL PRESSURE REGULATOR ON FUEL RAIL.IF REGULATOR DIAPHRAM IS BAD IT WILL LEAK FUEL INTO VACUUM LINE THAT IS ATTACHED.[/quote:886ad821ec] i replaced the fuel pressure regulator and solved the problem thank you
Dec 5, 2008 at 9:58 AM
