1992 Ford Explorer front brake smokes
1992 FORD EXPLORER
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHARLESDW
I had just replaced my front brake pads and the left front is smoking why?
Nov 7, 2008 at 9:33 AM
  • 31,937 POSTS
Hi there,
did you make sure that the caliper slid pins were free? is the wheel dragging on the brakes? jack up and spin to see if it is dragging, are you using good quality pads as cheap pads will smoke a lot when bedding in. check these things first.
mark (mhpautos)
Nov 7, 2008 at 10:16 AM
