1992 Ford Explorer Fluid in Radiator
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
WOLFN69
I have a Brown fluis in my coolant. There is no oil loss no foam on oil cap. Transmission slips a little. Is this Trans fluid in my radiator, I have no foam on my transmission fluid stick either.
Mar 21, 2010 at 11:30 PM
  • 110,251 POSTS
Is that trans fluid low or contaminated?
Mar 22, 2010 at 12:25 AM
WOLFN69
[quote:bdfff50a05="Jacobandnickolas"]Is that trans fluid low or contaminated?[/quote:bdfff50a05]
Trans fluid was low ,put fix leak in trans and havent had shifting problem since. Just worried about the brown oilly residue in radiator.
Mar 22, 2010 at 2:58 AM
  • 110,251 POSTS
The reason I asked about the trans is because the cooler is built into the radiator. I have seen them go bad and cause ATF to mix with the coolant.
As far as it being brown, if it appears there are no leaks, I would recommend having the system flushed. It could be that the coolant is that dirty or a prior owner put a stop leak in it.
let know what you find.
Mar 22, 2010 at 3:33 AM
