1992 Ford Explorer electric 4x4 shift
1992 FORD EXPLORER
252,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOUG CHEESMAN
truck will not shift into 4 wheel drive
diid show a drian on the volt meter but did not shift in not shows no drain and no shift
Jan 14, 2008 at 7:39 PM
T-MAN
  • 9 POSTS
[quote:01b3f92ba2="doug cheesman"]Transmission problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic 252000 miles
diid show a drian on the volt meter but did not shift in not shows no drain and no shift[/quote:01b3f92ba2]
electric motor turns transfer case in/out of 4wd...replace,or if mechanically inclined,it is possible to remove motor and clean contacts/brushes inside...thanx ford for design flaws
Feb 17, 2008 at 5:27 AM
